 well,
 well, just try to add a coupling capacitor (22nF) between the cathode of the first triode and the tone stack. It may fix your bugg.
it is always advisable to 'protect' the tone stack with a coupling capacitor.
Hello Charpy!charpy a écrit :well,
Hello Charpy!charpy a écrit :have you made the version with "volume" after the tone stack plus "master volume" just before the power tube?
have you got the effect loop (a source of many problems...)
does the trebble or bass pot change something (like the volume pot does)?
silver-mica caps does not support to be overheated, if you have solder + unsolder it a couple of time it may have suffered.
eventualy the coupling capacitor before the master pot may leak, or the bloking distortion is too strong (so increase R18 att the EL34 grid) reduce the value of the master pot to 220k log in oder to drain more current from the EL34's grid to the ground (weird but possible because of the dispertion of tube caracteristics).
stard with easy change before you change the OT or tubes... but check the bias anytime
Hi McColson...McColson a écrit :Cool ! stop, don't touch anything, close your chassis and pray for this amp working all his life
Hello McColson,McColson a écrit :Yes you can add a switch I have try on my G5, it's fun, but the voltage drop with the rectifier tube, change the HT and the bias.
here it's my schematic :
http://emmeffects.free.fr/MonG5/MCG5.gif
If you use a DPDT try to place a zener 20V on the PM, maybe need to place the fuse in other place (i don't know, i wrote rapidly), with the 1N4007 configuration to lower the HT in this mode so the difference with the rectifier will be lower.
For tasting many power tube, you have to solution, try SE fixed bias from the 50V bias tap, or try our system bias :
http://www.projetg5.com/modules.php?nam ... =0&thold=0
PM means the center of the secondary on the power transformer (PT), and the HT means "Haute tension" in french, High Voltages in english.Frank a écrit :Hello McColson,McColson a écrit :Yes you can add a switch I have try on my G5, it's fun, but the voltage drop with the rectifier tube, change the HT and the bias.
Call me stupid but can you explain me more what i´ve to do ?
What means PM and HT .... Sorry but i´m newbie with Tubeamps...
I´ve downloaded the "Schema G5 EZ80/81" and changed the amp shown in the schema!
It was only a test and the sound wasn´t so good. Is that the result of the other voltages?
About the bias... Yes i´ve thought about your version of the variable bias setting. I´ll give it a try today, if i´ll get the parts at my local dealer
Regards,
Frank
Hi McColson,PM means the center of the secondary on the power transformer (PT), and the HT means "Haute tension" in french, High Voltages in english.
The sound maybe sound not so good because the bias isn't not optimal when you use the EZ81. Try to use a system bias to re-bias correctly with the EZ81. And forget the trick with the zener for the moment.
Hi !McColson a écrit :My G5 with the EZ81 (the EZ80 has too voltage drop) and a 6V6JJ is one of my main configuration.
You can use our beautiful tool build by blacksnake : Electrosuite.
This tool is free and downloadable here in the section "Projets et Outils" in the under section "Outils" (Tools).
With the bias system, you will be able to load the 6V6 à 100%, and if it's sound not bassy call me
 well it sounds that your config is really bassy
 well it sounds that your config is really bassy  okay i´ll give it a try  8)
  okay i´ll give it a try  8)  I don´t speak and understand France language but this will help me a lot! Thanks!!!
A oui ! Really bassy my speakers where jumping aroundMcColson a écrit :You have my sample here :
http://mccolson.free.fr/sample/
Listen the Bossa 6v6 one and Aubert 6v6, I play a strat with single coils, so it's not specially bassy but you feel the 6v6 sound.
Frank a écrit :A oui ! Really bassy my speakers where jumping aroundMcColson a écrit :You have my sample here :
This sounds good okay, tomorrow i´ll try it again!
Thanks,
Frank
