L'AVALPIERRE OUAF OUAF! LE VOX AC3O A 4 EL84 CLASSE "A" (CHAUFFE COMME UN POELE A BOIS!) DONC UNE DYNAMIQUE D'ENFER(J'AI VENDU LE MIEN À UN POTE,PAS CHER ,IL ÉTAIT DES ANNÉES 60) LE MI 60 CLASSE AB ET EL34 (CHAUFFE MOINS LA HT NE DÉBITES QU'EN PRÉSENCE DE SIGNAL) MOINS DE DYNAMIQUE ET TEMPS DE RÉPONSE + LENT SURTOUT POUR LES TRANSITOIRES . LA CLASSE"A", LA ROLLS DES AMPLIS ,DÉFAUT(LOURD GROS TRANSFO D'ALIM ET CHAUFFE BEAUCOUP) J'AI UN GRUNDIG 2X100W (TAILLE D'UN GROS LIVRE DE POCHE4 ÉPAISSEURS + DE 10KG, DEDANS 4 ÉNORMES CONDOS, UN GROS TRANSFO TORIQUE ,LA CARCASSE SERT DE RADIATEUR)J'AI FAIT DE LA SONO AVEC, SONO QUALITÉ HIFI,ENCEINTES JL COOPER(COCORICO ACOUSTICIEN FRANÇAIS) A BASE D'HP ÉMINENCE BASS REFLEX TRÉS COMPACT(LE COPAIN CROYAIT QUE C'ÉTAIT LES ENCEINTES DE MA CHAINE)CONCLUSION:SI VOUS VOULEZ UN "BON SON" IL FAUT :UN BON PRÉAMPLI,UN BON AMPLI(BIEN CABLÉS AVEC DE BONS COMPOSANTS ) ET DES SUPER ENCEINTES ,C'EST COMME POUR LA HIFI,  QUI PEUT LE + PEUT LE - À LA LIMITE UNE BONNE CHAINE HIFI AVEC TRANSISTORS  FET(COMMANDE EN TENSION COMME UNE LAMPE,SCHÉMAS ET COMPOSANTS PLUTOT RARES)  " HH" EN FABRIQUAIT UN (OU PLUSIEURS) PRÉAMPLIS A LAMPES 2 BONNES ENCEINTES ETGAMELLES DE SUPERMARCHÉ PROSCRITES) DU TEMPS POUR RÉGLER TOUT ÇA(APPAREILS DE MESURE ET SURTOUT "DE BONNES OREILLES)  J M P
PS
OUR LES HP ,SIARE, SUPRAVOX'(LE MUST,J'EN AI 2 VIEILLES MAIS TRÉSVIEILLES), AUDAX(ENCORE COCORICO) EN HI FI, MAIS PAS POUR GUITARE(LA MEMBRANE S'ENVOLERAIT),SAUF LE 30CM AVEC MEMBRANE" ROUGE,EN BOIS...ENFIN PRESQUE(BANDE PASSANTE NULLE DANS LES AIGUS) DE MON 1ER AMPI(KIT DE LA StéRECTA PARIS,2EL34 ,ALLURE D'AMPLI DE CINÉMA MAIS EXCELLENT)  J'AVAIS AUSSI UN AMPLI PUSH PULL ULTRA LINÉAIRE(AVEC TRANSFO A PRISES D'ÉCRAN) D'EL84 QUE J'UTILISAIT AVEC UN ORGUE ET DES HP RÉCUPÉRÉS DANS DE VIEUX POSTES DE RADIO, LA PROCHAINE FOIS  LA PRISE PICK UUP DE LA RADIO DE MON GRAND PÉRE!FIN DÉFINITIVE
