New version of G5 released!!! G5v3
- charpy
This new version of G5 may be the ultimate one! The team did a lot of work : 1000 hours of work, 200 days, one hundred componants in the kit, and 50 email to dirk (tube town)
the improvments from V2 to V3 are :
-different values of tone stack componants for more tuning range 8)
-new power and output transformer : custom and "made in france" 8O
- power supply with LC filtering for lower hum
-power tube range from EL84 and 6V6 to KT88 at 100% bias! (check the pinout and socket if different than EL34) 8O
- new stand-by wiring for a smart switching (capacitor pre-load at 20V)
- onboard security LED, red light when high voltage is present!
- still low cost : 179 Euros at tube-town, germany this include cahssis, transformers, tubes all the hardware exept knobs and tools. you must also add the shipment.
but
- the kit does not include the "chiken head" knobs anymore, you have to add the knobs you like to your ordrer
- nor stand-by light
- not yet "building instructions"
the G5v3 schematic :
http://www.projetg5.com/Projets/G5/G5V3 ... cielle.pdf
add-ons Kits are coming :
- line out with analog speaker simulator,
- "variable bias system" for an easy and fast bias adjustment when changing tubes,
-tremolo,
-mmm.... let us finish that first...
layouts are coming (minor changes from V2 in tone stack and power supply boards but 3D-design )
power supply board 2D
http://www.projetg5.com/Projets/G5/G5V3 ... alimv3.pdf
power supply board 3D and viewer
http://goofaman.free.fr/papa/solidworks ... alimv3.rar
temporary file for audio board 2D (still at work)
http://goofaman.free.fr/papa/solidworks ... uille1.pdf
temporary file for audio board 3D and viewer
http://goofaman.free.fr/papa/solidworks ... 3REV03.rar
but
-tremolo,
Hello Steven,
Here the layout of the chassis ( only dispositions of differents items)
chassis herethe rest is comming soon
Re : New version of G5 released!!! G5v3
Hi
Is the complete layout still in progress or did i miss it?
Greetings
Greetings
The most recent layout is here :
http://www.projetg5.com/Projets/G5/G5V3/layoutV3g.pdf
But in fact, you must deplace the FX loop, because the FXloop is too close from the standby switch.
So delete the master volume option, and deplace all the potentiometers and the FXloop to the inputs, like thaht you have more than 5-6 cm separate the fxloop and the standby swith and the G5V3 will be humless.
Thank you, that was exactly what I'm looking for. And very quick answer, if have more questions I will be back. 8)
No problem, come back when you want !
You are welcome, Uhl_j !
