Posté : 12 déc. 2006, 8:06
Boa, mais j'ai (presque) rien dit, moi !
Définition d'un métal: plus la température baisse, et plus il est conducteurcharpy a écrit :l'oxyde est isolant (seul les métaux sont conducteur et certaines formes du carbonne).
Je ne suis pas convaincu...charpy a écrit : je pense qu'il s'agit d'un effet couronne (ou corona) ou les atomes périphériques de la cathode (donc le revétement emetteur d'électrons) s'ionisent et sont projetés vers la plaque.
http://fr.wikipedia.org/wiki/Effet_corona
le revettement émeteur d'electrons est un mélange de matériaux (thorium et....) qui ejecte les électrons périphériques par agitation thermique lorsqu'ils est chauffé. sans HT les electrons retombent sur la cathode avec HT ils migrent vers la plaque.
La réponse :Hello,
I am a french student in EE, musician, and passionate about old stuff (well, in fact I'm also passionate in some new stuff, but that's not the point here). I've been working on tube amplifiers for not that long, in fact I'm still learning. EE studies no longer cover tube technology, so I have to find infos by myself. In this search, your particular website, Fun with tubes, has alleady been quite helpful. And before asking my question I would like to thank you for sharing your knowledge.
I would also like to apologize for the length of what I wrote just down there. I'm not asking something randomly, I have a precise problem, so I think it's important to give you all I have so far, in order to get an accurate answer.
What pushed me to email you is a question that troubles me and some people I work with. We searched a lot, we thought about it, we read, but we got nothing clear enough. We have hints, not really more.
The question we were trying to answer was the point of using a "Stand-By" switch on most of the tube amplifier for guitar. Usually, on guitar tube amplifiers, there is a "ON/OFF" switch which put line voltage on in the power transformer, powering the heaters, the rectifier (solid state or tube), and sometimes the grid bias. Then, there is a "Stand-By" switch which put on or off the high DC voltage after the rectifier.
A schematic being more helpful than a thousand words, you can find an example of this on this Fender Twin schematic (here, the ON/OFF switch is labelled "AC Switch") :
http://www.freeinfosociety.com/electron ... php?id=922
I don't know if you're familiar with the guitar world, but tubes are something "magical" for most of the guitarists. In two ways : the sound is wonderful, and most of the guitarists don't have any idea on how they work and why they sound wonderful. In this particular context, there is some kind of rituals all around tube amps, some rational, and some... quite mysterious. This Stand-By switch is at the heart of one of them. We're "supposed to" switch the ON switch first, then wait for some times, and then switch the Stand-By on. The main reason for this is believed to be : "let the tubes heat before applying high voltage".
But some amplifiers don't have a stand-by switch. The schematics you give on your site don't have any either. Hence the question, is this switch really usefull ??
So my problem is to discover if this is rational or not. If this standby switch is here just for some kind of "religious" belief, or for a good, logical, ie cartesian, reason.
Some guys answered their ways :
http://psg.com/~dlamkins/Articles/stand ... at=musings
This question emerged again as I was reading your "Restoring Dead Capacitors" page. Here is what made me react :
>Some people say...
>Some people say you can reform capacitors by connecting the equipment to a variable transformer
>and slowly bringing up the voltage. If the unit has solid state rectifiers this can be done. However,
>this can ruin a rectifier tube by damaging the oxide coating of its filament or cathode.
The "damage of the oxide coating" is the most recurrent reason we came across. Applying high voltage on the tubes when they are cold would damage them, by ruining their cathode, more precisely their oxide coating. This could be a correct explanation, but...
...but 2 questions remains :
1) If this is true, why do some (many, in fact) amplifiers not have this switch ?
2) If this is true, why do this happen ? What is the physical explanation of this damage ?
For the first point, some people claim that a rectifier tube induces a timing between heating and high DC voltage. So, the stand-by switch would be useful for solid-state rectifier amps only. But then again, some tube rectifier amps have it, some SS rectifier amps don't have it... Furthermore, the same problem would be deplaced on the rectifier itself : it is first cold when the high voltage is applied.
So there we are...
As you speak about this on your site, I hope you will be able to bring some light on this subject. Is this damage real ? Why would it occur only when we slowly raise the power ? And what do you think of the use of the stand-by switch ?
I thank you if you take the time to read all this, and to answer me. I'm an engineer, I like to understand what I'm doing, so I'm spending lots of time studying, and this particular point remains doubtful for me.
Cordialy,
Pour moi on en est donc au même point : l'interet pratique, mettre l'ampli en pause sans le refroidir, est clair. L'interet sur la durée de vie est "connu", mais est-il réel ou pas...First of all to clarify my statement about rectifiers. If a variable transformer is used to bring up the voltage slowly on a tube rectifier power supply the tube will be called upon to deliver current for an extended period of time without the cathode being up to its design operating temperature. This can seriously damage the cathode's surface and shorten the life of the tube.
In an amplifier operating at normal line voltage, if the b+ comes up before the tube cathodes are hot there may be a short period in which positive ions bombard the cathode before the space charge forms which protects it in normal operation. Whether this does or does not shorten the life of a tube is the subject of a lot of debate, but as far as I know there has never been a scientific study of this subject.
The issue of rectifier warm up time depends on what tube type is used. A 5U4 warms up very quickly as compared to amplifier tubes. There is a type 5AR4 that has a slow warm up time that matches the amplifier tubes. Also the 5V4 is a slow warm up type.
As I see it the main advantage of a stand-by switch on a guitar amp is as follows. The amplifier can be left on in stand-by mode while the lights are being adjusted and the stage set for the performance. The amp is warmed up and ready to go but is in a low stress condition. When the musicians come on stage the guitarist or a stage hand can flip it to operate and it is ready to go. God help the stage hand who forgets to turn on one of the amplifiers for a Rolling Stones concert.
Regards.
exactement... il faudrait qu'elle chauffe elle aussi je pense... enfin je sais pas. Je devrais être capable de répondre normalement, j'ai vu ça à l'école, mais je me souviens plus.Basstyra a écrit :Cela dit, faudrait mesurer tout ca. Pourquoi les ions partirait-ils de l'anode ? HT je veux bien, mais bon, ca reste "que" 500v au pire mettons.
quand ça bombarde, d'une part ça bouzille la couche d'oxyde en éjectant des atomes, qui par exemple peuvent venir se condenser sur le verre du tube ou je sais pas où, ça modifie donc la chimie. Et puis ça fout le boxon dans les charges de la cathode+oxyde qui se trouve chargée positivement, mais ça je pense pas que ce soit un réel probleme, faut pas oublier que la cathode est reliée (via une résistance) à la masse.Basstyra a écrit :De plus, si recombinaison dans la ZCE il y a, ca doit faire du dépot de matiere qq part... Et ca, c'est inévitable. Peut etre est-ce une cause du vieillisement des tube ?
Je crois que l'on est bien d'accord, mais que je me suis mal exprimé.Basstyra a écrit :Je parle de recombinaisons, là, donc d'atomes, neutres. Les ions+ de l'anode rencontrant les e- de la charge d'espace. Donc il n'est pas question d'élimination via la masse, ou de perturbation de la charge (enfin sauf par la recombinaison qui retire des e-, mais imaginant les quantités je pense pas que ca soit un soucis). C'est un soucis de matière, là.
Avec du bol, en effet ca part sur le verre. Avec moins de bol, ca part sur la cathode, bloquant un peu sa capacité d'émission. Non ?
ouaip.Basstyra a écrit :Ca pourrait faire un joli problème à étudier, ca, l'inluence des ions + venant de l'anode sur le vieillissement de la cathode dans les tubes électroniques. Si je suis pas pris dans la boite ou je souhaite faire mon PFE, je proposerais ce sujet à l'école, tiens !
