Page 3 sur 3
				Posté : 27 sept. 2006, 11:58
				In class A you can bias at 100% of the plate dissipation
A 6v6 has a plate dissipation of 12W
If you have the plate voltage and the current, you have the power dissipation :
P = U * I
So You must check the plate voltage, because 45mA at 300V or à 100V isn't not the same plate dissipation
Try to bias at 100% of your plate dissipation,a nd tell me how you feel the sound.
				Posté : 27 sept. 2006, 12:12
				par Frank
				McColson a écrit :In class A you can bias at 100% of the plate dissipation
P = U * I
Okay, I knew Mr Ohm
  I´ll try it, but i´m a bit scary about tweaking the tube to 100%. In the tubesheets they are talking about 250V and 45mA in class A. So i didn´t know what to do
Regards,
Frank
				Posté : 27 sept. 2006, 15:14
				Frank a écrit :McColson a écrit :In class A you can bias at 100% of the plate dissipation
P = U * I
Okay, I knew Mr Ohm
Regards,
Frank
250 *0.045 = 11.25W so very near the maximum plate dissipation !
Don't worry to bias your tube at 100% in class A single ended, it's very standard.
Enjoy !
				Posté : 27 sept. 2006, 19:09
				par Frank
Enjoy !
Okay you win !
I´m now at 93% "taux de bias" and it sounds great!
Thanks for your help, i think i don´t change anything to this Amp now!
Now I´m going to build a case for it, but first i need a speaker...
Regards,
Frank
				Posté : 27 sept. 2006, 19:24
				Good, I was pleased to help you.
				Posté : 27 sept. 2006, 19:58
				par Frank
				McColson a écrit :Good, I was pleased to help you.
Nice talking (writing)
 with you , thank you (all) very much again!
Bye,
Frank
