Gain reduction
Come talk about our DIY amp project...in english !
slajeune
Message non lu par slajeune »
Hi Steven,
thanks for the update. With all of the info, I would go with a 5751. This might be what you are looking for. The ECC82 has a gain factor that is way too low (20 vs 100!). A 5751 or a 12AT7 might get you close to what you are looking for.
Cheers,
Stephane.
sjhusting
Message non lu par sjhusting »
yes, i thought the ecc81 was a good compromise. I will try the 5751 from my Fender next time I am in the band practice room. And I will still put a switch on the bypass cap of v1a
thanks for all the input.
steven
sjhusting
Cathode bypass works wonders. I removed the effects loop (never used it anyway) and put a switch in one of the holes. Put the ecc83 back in ... perfect. And my cold solder joint is gone. Now I have to fill the other hole, maybe a master?
thx again
steven
Yes you can replace the R17 (1M) by a 1M log pot, and you search a clean sound, a master isn't bad idea.
